It is currently Tue May 27, 2025 12:19 pm
PostPosted: Thu Jun 16, 2005 5:23 am
What is everybody using for their offset (outer edge of string to edge of FB on E & e) just being nosiy
PostPosted: Thu Jun 16, 2005 6:01 am
It tapers from the nut on up but I like at least 1/8" on average. I like to play aggressive sometimes and tend to vibrato notes. If the string slips off the edge of the fret, I've made it too narrow. I'm probably not your average joe though. I've got long fingers and like to make wider necks because of that fact. It will be useful to know what to build as an average though. What should we make it for a guitar to sell?
Thanks for asking,
Wade
Nashua, NH
http://www.wadefx.com
Michael--I dunno. I simply make the fretboard--at the 14th fret--the same width as the string spacing at the bridge and it all works out. Eg., if the spacing is 2 3/16", then the fretboard is that width where it joins the body. Etc. It averages out to around 1/8, perhaps a bit more.
Does that help?Steve Kinnaird38519.6273263889
PostPosted: Thu Jun 16, 2005 6:05 am
I was refering to the nut position by the way
PostPosted: Thu Jun 16, 2005 6:13 am
I measure in 1/8th at the nut.
PostPosted: Thu Jun 16, 2005 6:38 am
1/8 on the little e and 5/32 on the big e
PostPosted: Thu Jun 16, 2005 1:48 pm
[QUOTE=MichaelP] I was refering to the nut position by the way[/QUOTE]
Oh
Ok, that number I do know. 3/32 on the little e, 1/8 to the center of the string slot on the big E.
PostPosted: Fri Jun 17, 2005 3:36 am
3/32" measured at the 1st fret. Outside of both E strings to edged of FB.
tim...
